Re: Allis B
Glowing where it's not supposed to
Ted Seifert
08-22-2000 09:51:23
The resistor is in series with the field winding of the generator ONLY in low charge. In all other switch positions the resistor is shorted out and the generator is in high charge. Look for a short to ground (chassis) for the wire going to the "F" terminal of the generator. Look for misswiring or a shorted field in the generator.
Good luck.
Scott Murphy
08-24-2000 11:23:38
 Re: Re: Allis B - Glowing where it's not supposed to in reply to Ted Seifert, 08-22-2000 09:51:23
That explains why it only gets hot when the switch is in the closed position. It still doesn't seem like it should get that hot (in the closed position) unless there is a problem somewhere else. Would a short on the "F" terminal wire or in the generator cause the extra load across the resistor or should I look elsewhere?
