Re: allis chalmers B clutch problems
DanD.
08-22-2000 09:04:05
How long of a time do you have to wait for the tranny to stop turning? When the tranny is hot and with thin oil in the tranny (assuming your B has hydraulics) it may take several seconds for everything to stop turning before you can shift. Does it slow down faster when the tranny is cold?
larry
08-22-2000 11:04:41
 Re: Re: allis chalmers B clutch problems in reply to DanD., 08-22-2000 09:04:05
Hi Dan, As soon as I started it after the clutch change it was difficult to shift. It takes aprox 20 sec to slow down and I noticed it is the worst if you are in neutral, let the clutch out push it back in and try to go to another gear. It will slow down much quicker if I throttle the engine way down. It seems like something is still trying to drive the trans with the clutch disengaged.
