Re: Allis B
Glowing where it's not supposed to
Karl in MD
08-21-2000 21:42:56
I don't think it should get hot enough to glow, but charging resistors do get hot. The reason it doesn't get hot with the lights on is that it's not needed. The lights use enough juice that the generator's full output is used (probably about 8 amps). Without the lights, and with the resistor in the circuit, it limits the generator's output to @2-3amps. The excess amperage is dissipated as heat. If it's getting hot enough to melt insulation, the resistor is bad, possibly shorted, and could, over time, damage the generator (especially if it burns out and allows an open circuit, which will fry the generator windings). Sorry so windy, hope this helps; Karl
