Slowing down a wd 45
Scott
08-21-2000 14:09:08
I have a wd-45 that I am using in antique tractor pulls, and I am looking for a lower gear for less ground speed. I'd like know if there are any deep reduction final drive gears or lower transmission/rear end gears available. Thanks in advance for any and all information
jody nusbaumer
04-03-2001 11:07:48
 Re: slowing down a wd 45 in reply to Scott , 08-21-2000 14:09:08
You do not want to slow it down. If anything you want to speed it up!! Unless you are dead weight pulling.
mark/indiana
08-22-2000 10:28:13
SCOTT.. I CAN'T IMAGINE WHY YOU WOULD WANT TO SLOW DOWN....THAT TRACTOR AT 3600-4500 POUNDS WILL HAVE ALL KINDS OF POWER AND NEEDS MORE GROUND SPEED...UNLESS YOU ARE NOT RUNNING STOCK RPM'S...AT 1800 RPM LETS SAY ..YOU ARE STILL PLENTY SLOW...WE ARE TALKING ANTIQUE PULLS USING FIRST GEAR...2.5 MPH STOCK..AGAIN TOOO SLOW
Roger Hogenson
08-22-2000 09:44:21
Buy yourself a wd45d (diesel) rear end. They are geared lower. The diesel runs faster (rpms) so to keep ground speed the same and pto speed the same they geared down the diesel. I am in the process of putting one in my pulling tractor.
tim[in]
09-05-2000 23:40:58
 Re: Re: slowing down a wd 45 in reply to Roger Hogenson, 08-22-2000 09:44:21
which set of gears is it ? the tranny ,differential,or rear end gears that slow it down and how much does it slow the ground speed down? will these fit in a straight wd? thanks in advance!!=)
