Model B Transmission Lube
Rick in NC
08-21-2000 11:57:36
I use hydraulic-transmission fluid in my 1950 A-C Model B and it seems to work great except for a couple of things:
1. Since I changed from the 20W oil that came in the tractor when I bought it, the transmission seems to take forever to quit rotating when I push in the clutch. I usually wind up grinding gears.
2. The implements seem to drop a whole lot quicker when I push forward on the control lever and seems to creep down faster.
I know that all of this is to be expected from a thinner consistency oil.
Question: How much thinner is the hyd-trans fluid than the 20W oil? Is 30W oil too thick to be used in the hyd-trans in the summer?
On my old Farmall, the transmission stops rotating immediately because of the 80W oil.
Thanks for any help or suggestions.
T ed Seifert
08-22-2000 09:59:53
 Re: Model B Transmission Lube in reply to Rick in NC, 08-21-2000 11:57:36
The AC B book says use 20 w oil when the tractor is equiped with hydrolic pump> There is a thumb screw on the pump near the linkage connection that regulates the let down speed.
