Dual front wheel shakes
donald peake
08-17-2000 09:37:20
I WOULD LIKE TO KNOW IF ITS NORMAL FOR THE FRONT END OF MY WD TO SHAKE AND WOBBLE WHEN YOU I DRIVE OVER NOT SO LEVEL GROUND. THERE IS PLAY IN THE STEERING AND I HAVE POWER STEERING. WOULD APPRECIATE A METHOD OF FIX IF NOT NORMAL.
tadams
08-18-2000 04:51:12
 Re: dual front wheel shakes in reply to donald peake, 08-17-2000 09:37:20
Have you checked the universal joints in the steering shaft?
Tom
Phil Auten (TX)
08-17-2000 10:58:07
Donald,
Probably worn bearings or gears in the front end. You will need to replace the worn parts to fix it, unless the WD-45 has the steering gear that can be rotated 180 degrees to use an unworn section. Not a difficult job, but many of the parts are HEAVY, so be careful.
Phil
donald peake
08-24-2000 17:35:16
 Re: Re: dual front wheel shakes in reply to Phil Auten (TX), 08-17-2000 10:58:07
thanks guys i will try to fix.
