AC-B trans parts needed
David (Ala)
08-16-2000 10:57:09
I need 1) two- reverse idler gear shaft straight roller bearings 2) spring washer that goes on countershaft next to front bearing in trans 3) may be interested in brake drum for 1940 B.
Thanks, David
Dick L SAE Standard torque values
08-17-2000 07:10:25
 Re: AC-B trans parts needed in reply to David (Ala), 08-16-2000 10:57:09
Here you go. Chart is a little old, check out nut sizes.
Grandad (MI)
08-16-2000 18:12:25
Roger VanCamps phone number is (219)747-3455 but he will be at the Portland, Indiana show until Sunday.
Dick L
08-16-2000 11:40:53
I will try to get you torque values and phone numbers after I get home tonight. Roger VanCamp should have the used parts at his scrap yard in Fort Wane, IN. I don't seem to have the phone # with me. The torque values will be standard values for bolt sizes shown on the chart that comes with a torque wrench.
