DIFFERENTIAL oil on WD
M.L.
08-16-2000 09:50:08
Where do you check the diff oil on 51 WD. What kind of oil do you use. Also where do you check the trans oil and what kind to use. THANKS
Farmboy
08-17-2000 07:14:10
 Re: DIFFERENTIAL oil on WD in reply to M.L., 08-16-2000 09:50:08
The differential check plug is under the left foot rest, you have to remove it to get to the plug. The tranny check plug is just in front of the other. There's a third one still in front of the tranny plug for the hand clutch. All three are actually connected and use the same 80 or 90 wt tranny oil. You should however check each because each chamber has about 3 inches of capacity below the holes that connect each. One could be bone dry while the others have 3 inches of oil still left. Hope this helps
