Allis G clutch problems
Philip Croff
08-15-2000 07:05:03
When I let the clutch out on my G, the clutch makes a loud squeeking noise. When the clutch is out,, I can't even hear the tranny. Is this a worn throwout bearing?
Paul from Michigan
08-15-2000 20:09:40
 Re: Allis G clutch problems in reply to Philip Croff, 08-15-2000 07:05:03
I assume you mean it makes the noise as the clutch engages, but stops when the clutch is fully engaged. Also that it doesn't make any noise when the clutch pedal is held down, disengaging the clutch. In that case, it sounds like a worn disc & rivets are grinding on the flywheel and/or pressure plate. Ususally throwout bearings make noise when the pedal is depressed, which puts load on the bearing.
TED
09-14-2000 11:17:51
 Re: Re: Allis G clutch problems in reply to Paul from Michigan, 08-15-2000 20:09:40
MY "G" MADE THE SAME TYPE OF NOISE WHEN RELEASING THE CLUTCH. NEVER ANY PROBLEMS. RESTORED THE TRACTOR AND PUT IN A NEW CLUTCH AND PRESSURE PLATE-BEARING. STILL HEAR THE SAME NOISE ONCE IN AWHILE. MUST BE NORMAL.
