Oil pressure
paul
08-14-2000 10:48:02
i have ca model i changed the engine i put a b model engine it is a ce engine i would like too know what the oil pressure should be i changed oil and filter it is pumping oil but i dont seem to have pressure i think it should be around 12lbs pressure
Phil Auten (TX)
08-14-2000 11:06:27
 Re: oil pressure in reply to paul, 08-14-2000 10:48:02
Paul,
There should've been a tube pressed into the base for the oil filter. Sometimes these tubes are missing and the oil pressure will be low because of that. If it is missing, you should be able to pull the one from the original engine and press it into the new engine.
Phil
