Hydralics
Jeff Reeves
08-11-2000 12:20:31
I have a wd and the hydralics bleed off when using my brush hog,and it drops the front of the brush hog to the ground, is there anything I can install to fix this?
dick ray
04-30-2001 13:40:21
 Re: hydralics in reply to Jeff Reeves, 08-11-2000 12:20:31
hi,we have a powerpack and it keeps jamming.we are condensing chopped up cardboard and pushing into a four inch diameter tube.we need advise as to how to increase power,it is very close to working.if you could help we would appreciate it very much thank you,dick ray
Farmboy
08-12-2000 13:47:52
Jeff have you tried adjusting the linkage to the hold valve? Try lengthening the rod from the lower valve to the upper hold valve. If that doesn't help, the ball and seat in the hold valve is not sealing. The IT manual says you can take a new ball and drive it into the seat with a soft drift punch and 16 oz hammer to re-seat it. Hope this helps.
Farmboy
RMD
08-11-2000 21:14:04
I'm assuming you have a 3 point hitch adapter on your WD (snap-coupler mowers are rare). It won't fix the hydraulic bleeding, but a lot of people set chains from the top link to the lower links so that the mower rides at the same height all the time when lowered. This would also keep the lift linkage from droping below that height. You can make up your own, or most farm stores sell the chains and brackets as a set.
