Re: will a wd 45 engine fit into a rc
Karl in MD
08-11-2000 01:12:36
I'm not sure about the clutch housing, but the frame rails are pretty much the same. If you're putting the 45 motor in the RC, you're going to have to baby the drivetrain some; the RC has the same transmission as a WC, but the pinion in the rear isn't straddle mounted (it has a bearing behind it but none in front) so if you get it in a gripe the pinion could try to climb the ring gear, so you get a BANG and a tow rope. Check the I&T manual, it shows the differences between the two. You'll also need the 45 radiator and I think the hood, too.
Jeff in Mn.
08-14-2000 13:25:48
 Re: Re: will a wd 45 engine fit into a rc in reply to Karl in MD, 08-11-2000 01:12:36
A Model 60 combine also has the same motor. The only differece is the govenor. Runs a little faster.
