Alyce's hydrolics
Bob
08-10-2000 11:22:43
My Alyce has several leaks around her hose fittings, I have checked but perhaps failed to find the right spot to check and add fluid. (She is a recent find). She is a WD with a smooth motor but she does smoke a bit. Handles a back blade and bucket really welll, want to try her on bush hog but want to be sure there are no low fluids. Where to look?? I have been watching the transmission, just in front of the foot clutch. where else is there? thanks, Bob
Farmboy
08-12-2000 14:01:26
 Re: Alyce's hydrolics in reply to Bob, 08-10-2000 11:22:43
They hydraulic oil has a small dipstick thart is just in front of the tranny fill plug. There are four plugs in all: from front to back: the hydraulic is one with the dipstick, behind that is noe for the hand clutch, behind that is the transmission, then the last one is hard to see under the left foot rest is the rear end. All but the hydraulics are connected, but if you have never checked before, check all and top off as needed. The hole connecting each chamber is about 3 inches up and either one can be dry from a leak while the others are OK. The hydraulics call for 20W non-detergent oil, the rest plain 90W tranny oil. Hope this helps
