Model B mounted plow questions
Butch (OH)
08-08-2000 06:59:27
I have two 1 bottom mounted plows for my model B. One of them has an rock shaft about 1 1/2" diameter for hydraulic lift but I don't have the brackets that mount the rockshaft to the tractor. The other has two arms that look like they would attach to a cultivator or similar type rock shaft. Went to an A-C parts yard last weekend and looked at quite a few tractors with cultivator rock shafts and different brackets on the back, but none would work with either of my plows. Need advise or parts to get either one hooked up to my B. Thanks
D13
08-09-2000 14:53:12
 Re: Model B mounted plow questions in reply to Butch (OH), 08-08-2000 06:59:27
Butch, we had a discussion on this some months ago (February?). I wrote a tiring note on how mine mount. You might see if it is still in the archives with key word plow, perhaps B or AC also. The plow, front drawbar, rockshaft, and mounts are identical between the manual and hydraulic units. Only the lift lever is different. The one from the B cultivator will not work. If you cannot find the old one I will try to reconstruct it but it's been a while.
Butch(OH)
08-10-2000 09:35:31
 Re: Re: Model B mounted plow questions in reply to D13, 08-09-2000 14:53:12
Thanks D13 for the help. I have all of the mounts and brackets for the front end, but the rear is giving me fits. I looked at several cultivator rockshafts before I posted my message and none of them were set up for my plow. I have since been informed that some will work with the plow or culivator and some will only work with the cultivator. Guess I will have to keep looking for a rockshaft with the correct mounts.
Dick L
08-09-2000 08:48:13
Butch, I have several Allis manuals that I bought on ebay, I think one was a plow manual, if it is I will copy the pages you need and send or e mail them to you. If it was not in this batch I will be getting more for my collection.
