WC manifolds
Bama Dee
08-03-2000 17:33:50
What is meant by the term " dual fuel manifold", what makes them different from a regular manifold?
Tadams
08-04-2000 04:31:14
 Re: WC manifolds in reply to Bama Dee, 08-03-2000 17:33:50
A dual fuel manifold has a plate on it that can be turned to make to burn kerosene. When you turn the plate one way it make the manifold prheat the kerosene to burn better, when turn the other way it is set for gasoline.
Tom
Aaron
08-03-2000 21:40:41
The dual fuel was the one that was side discharge. The outlet for the exhaust was turned up for kerosene and down for gas (might be vice-versa, I forget). The single fuel one discharged out the top of the hood.
Aaron
