Hydraulic fluid for WD
Mike
08-03-2000 11:58:32
Can someone tell me what type oil to use in hydraulic system. I think I found the spot where it goes theres a small dipstick in front of the foot clutch that says check with rams extended. Is this the right place? Much appreciated.
Sandy Lake Implement
08-06-2000 06:58:54
 Re: Hydraulic fluid for WD in reply to Mike, 08-03-2000 11:58:32
We use 30 non detergent which is still to be
found locally. The new multipurpose oils are
thin enough that you may experience leaking
past the old seals.
Richard (KS)
08-03-2000 12:26:18
You have found the correct place to fill and check the hydraulic oil level. The pump runs whenever the engine is turning so you really don't want to let it run dry. I've been using universal tractor hydraulic oil from the local NAPA. Originally the owners manual called for non-detergent SAE 20 engine oil but this is getting hard to find, and the new hydraulic oils are better anyway. The main thing is not to use detergent oil as it will foam and cause grief.
