Cylinder Hydraulics Failure on AC7060
Don Doerr
08-02-2000 08:43:52
Where do I start looking to fix this problem? The 3 point works fine but did not try it with weight. The cylinders stopped working while disking and everything else seems normal.
Gordon Chance
08-02-2000 18:33:07
 Re: Cylinder Hydraulics Failure on AC7060 in reply to Don Doerr, 08-02-2000 08:43:52
Don:
You need to start by checking the stand-by pressure of the piston pump. On the rear of the tractor on the right side you will see a Tee with a hose attached to the front of the tee and the rear of the tee capped. Remove the cap and attach a hydraulic hose with a #6 JIC female end on the hose to the tee with a 5,000 PSI pressure gauge on the other end of the hose. Start the tractor and with the hydraulic levers in neutral the gauge should read the stand-by pressure that the piston pump is producing. The pressure should be in the 400 to 600 PSI range. If the pressure is much lower then the piston pump will not produce high pressure when you pull a hydraulic lever. If the stand-by pressure is low, then you will need to check for a broken spring in the low pressure spool of the compensator valve. The compensator valve is located on the front of the piston pump which is on the right side of the tractor beneath the batteries. The compensator valve will have a large and a small hex cap facing out toward you when you look at the valve. Remove the small cap and check for a broken spring or broken spring stop. This is usually what I find to be the problem in a situation like yours. There are shims between the cap and the spring that you don't want to lose when you remove the cap. I hope that this helps and good luck.
Gordon
Aaron
08-02-2000 21:09:03
 Re: Re: Cylinder Hydraulics Failure on AC7060 in reply to Gordon Chance, 08-02-2000 18:33:07
Easier yet. One of those silly "did you check" things. Are the cables still attached at both ends? We have had the ball joint at the lever end break more than once on our 7060. I'd first check to make sure the cables are free and moving at both ends. Then jump into pressure checking and the like.
Aaron
