175 blowing water
Steve Carmack
07-31-2000 20:21:02
My AC 175 is blowing water about 6 inches high when I take the radiator cap off. Isn't this a good indication that I have a blown head gasket? The tractor worked all spring and summer till now.Thanks
Jim
08-06-2000 18:36:11
 Re: 175 blowing water in reply to Steve Carmack, 07-31-2000 20:21:02
these tractors had a common problem with the anitfreeze eating through the sleeves we had a 200 that did it after 10 years since an overhaul we now treat the antifreeze with a conditioner you want to make sure you aren't getting antifreeze in the oil. let it set overnight and take the drain plug out in the morning the water will go to the bottom. We then took the pan off and pressurized the radiator you could see the water shooting through pin holes in the sleeves i believe a complete overhaul kit for our 200 was about $750 . good luck
Mikedom
08-04-2000 13:37:08
Steve- I had a similar problem with my d-17. It would blow anti-freeze out the overflow after it warmed up and the temp gauge would cycle back and forth. Replaced the head gasket and everythings fine now.
