Need head gasket advice.
Dave
12-01-1998 08:11:11
I am presently slowly aquiring the parts to pull the head off of a 1952 WD. I need to replace the head gasket because it keeps siphoning coolant into the oil. I intend to replace the manifold bolts and rebuild the carb at the same time. I was wondering if anybody had advice or tips so that I get this right the first time.
Thanks in Advance. Dave
Tony H
12-01-1998 19:13:22
 Re: Need head gasket advice. in reply to Dave, 12-01-1998 08:11:11
You will need to replace the freeze plugs in the head. I would bet this is where the coolant is getting into your oil. You may have bad O-Rings on the bottom of the sleaves and this will require a overhaul. I would pull the head and if I did not find the problem here I would do a complete teardown. Gaskets are expensive to replace twice.
