Serial #
donald peake
07-30-2000 11:56:47
i have a wd allis chalmers and i would like to know if anyone can tell me what year this is. the number i found in front of the gear shift lever is 208663. this tractor has power steering and i understand that the power steering was not put on tractors untill 1956 or 1957.
DONALD PEAKE
08-01-2000 17:57:06
 Re: Re: serial # in reply to Aaron, 07-30-2000 13:28:16
HEY AARON:
I HAVE LOOKED ALL OVER THE PLACE YOU MENTIONED AND THERE IS NO NUMBER THERE. THE MOTOR NUMBER IS U301940. IT LOOKS LIKE THE POWER STEERING MIGHT BE A ADD ON. BOY SURE WOULD LIKE TO KNOW THE YEAR. THANKS AARON.
Aaron
08-01-2000 20:43:48
 Re: Re: Re: serial # in reply to DONALD PEAKE, 08-01-2000 17:57:06
That is another casting number. Engine serial number should be on the left side of the engine somewheer near the carb. Should start with the "WD" thing again. Not sure about the tractor number. Should be on the left rear of the rear axle on a flat. Tomorrow I'll get my camera out and take a shot of our WD numbers and put them on my web site.
Aaron
donald peake
08-03-2000 10:08:27
 Re: Re: Re: Re: serial # in reply to Aaron, 08-01-2000 20:43:48
HEY AARON
I FOUND THE NUMBER ON THE BLOCK UP UNDER THE MANIFOLD AND ITS WD38631PA. I REALLY APPRECIATE YOUR HELP. THANK YOU
