Allis Chalmers HD6 bulldozer
craig
07-29-2000 13:54:16
I have an opportunity to purchase this unit but, it has not been run in 7 years since it was driven off the truck. There is no water in the oil pan. Unit has hyd lift on blade and hyd ripper. Tracks are 50% according to owner. Unit is diesel. This is my first potential venture into purchasing a resoration project. My questions are,,,what would this unit be worth and what are some of the primary potential problems with purchasing a unit that has not run and been left outside for seven years.
thank you in advance for any guidance you can provide.
Loretta
05-21-2001 14:17:32
 Re: Allis Chalmers HD6 bulldozer in reply to craig, 07-29-2000 13:54:16
I know this doesn't exactly answer your question but I have a question for you. My father bought an HD6 Model Allis Chalmers two weeks ago and because he hates computers (won't allow one in the house) I am searching the web for him trying to find contacts for parts or catalogs of how to order parts. He too is a restorer (retired farmer). Can you give me any leads? Or maybe the two of you would like to talk trading part stories? Please email me at [email protected] and let me know. I appreciate any help you can give me :) Loretta
Rebecca Bowers-Heckathorn
09-16-2005 08:58:29
 Re: Re: Allis Chalmers HD6 bulldozer in reply to Loretta, 05-21-2001 14:17:32
I have been the owner of an "Allis Chalmers" HD6E Bulldozer since 1981 it is in good shape and was started and worked last winter when the weather was 3 below zero degrees--I have the books for same--it is a good tight machine that needs a good owner to preserve it.--I'm hoping you will get back with me soon and I can exchange further information with you requarding my machine.
ROBERT
07-29-2000 21:43:07
check the eng (not locked up). most lickly the streering clutch will need tor down and cleaned
and readjusted ( thay are dry clutchs and will
rust up). If you are doing a complet restore this will not mater becose you will have it all tore down any way. just by it cheep !! ROBERT
craig
08-01-2000 18:57:13
 Re: Re: Allis Chalmers HD6 bulldozer in reply to ROBERT, 07-29-2000 21:43:07
Hi Robert,
Thanks for the tips.
What you you consider CHEAP on a unit like this.
Also, ballpark on the resto you described if possible. Are we talking $5k or $2K. Also, if a diesel is seized, can it be bored or honed like gas, or is it shot? Never tore down a diesel but I have a good friend that spent 22 years in the engine room on nuke sub for the USN, I think he would help if it is salvagable.
Thanks in advance.
09-16-2005 09:05:21
 Re: Re: Re: Allis Chalmers HD6 bulldozer in reply to craig, 08-01-2000 18:57:13
