26 power adjust rim replace with combine wheel?
Bob H
07-25-2000 09:29:35
I need a 26 power adjust rim. My tube has been leaking calcium and I didn't notice. I never had to add air. The rim is shot. Any idea where to get a replacement without buying new? Since I also need a new tire and tube, the cost will be $500 or so to get me running again. Someone suggested buying two used combine wheels a tires ready to go and give up the power adjust feature. He thought I could get decent tires on 8 hole wheels for $100 a piece or so. Any thoughts on that?
GeneD14
07-25-2000 13:30:27
 Re: 26 power adjust rim replace with combine wheel? in reply to Bob H, 07-25-2000 09:29:35
Combine tires are usually wider than your originals so if you had tire chains they won't fit. Not having spin out rims will hurt resale value.
LB
07-25-2000 10:48:06
Hi, I have a D14 with combine wheels on the back. I think most will fit, but these are from an international combine.
