WD REAR END
JD
07-23-2000 17:32:57
WHERE TO CHECK AND ADD OIL TO THE RIGHT AND LEFT REAR ENDS
Brian G.
07-24-2000 05:48:52
 Re: WD REAR END in reply to JD, 07-23-2000 17:32:57
I assume you mean the "final drive" or "bull" gears? Keep filled to the "level plug". The book recommends draining and refilling twice a year and yet they didn't provide drain plugs. I always figure most don't get changed twice in the life of the tractor. I would recommend dropping the pans to get rid of any accumulated water and sludge. Use 80EP (80/90) gear oil. Each side holds 1-3/4 qts. Brian G.
jd
07-24-2000 17:36:40
 Re: Re: WD REAR END in reply to Brian G., 07-24-2000 05:48:52
Thanks Brain G.
