Adding Power steering to a WD45
Peter Hatlestad
07-18-2000 07:35:16
I would like to add power steering to my WD45. Are there kits available, and if so where would I find one.
Andy
07-18-2000 15:48:16
 Re: Adding Power steering to a WD45 in reply to Peter Hatlestad, 07-18-2000 07:35:16
I dont know if a paste job will survive, but here is the link( find it by searching Dana Hobson on unofficialallis)Topic: WD-45 Pictures Dana Hobson 7/12/00 10:03:20 AM I just finished my 1955 WD-45. Please check out the before and after pictures at this URL "" Thanks to all for all your help in this restoration project. Dana Hobson 033729RE: WD-45 Pictures Dana Hobson 7/12/00 10:04:57 AM Lets try the link again>Link
Link
033736RE: WD-45 Pictures Bob Conner 7/12/00 11:58:55 AM Dana, This is a beautiful tractor, great job! I am starting a 1956 WD45 wide front end next month. I just finished the engine. Can you tell me how your modified power steering works. What did it cost and did you have a kit or did you have to scrounge it all up? What did the paint cost? Thanks, Bob Conner
Phil Auten (TX)
07-18-2000 12:26:01
Peter,
I went back and found the post on the WD45 P/S and posted it below. The pump came off of a Ford heavy truck and has a remote reservoir instead of it being part of the pump. The steering "motor" is Char-Lynn and still available for around $300 from Char-Lynn, but according to Dana, the owner of the WD45, it is cheaper form other sources. The rest is assembled from custom built hoses and a Honda transmission filter. It looks like a great setup and Dana says it works great too.
Phil
Andy
07-18-2000 09:54:58
Peter, I dont know about custom kits, but there was a restoration link left at unnofficioalallis that concerned the use of a torque amplifier and a pump from an old car. It was a very clean looking job. The link was left about 3-5 days ago, Good luck
