Allis C wiring
Duane
07-17-2000 17:28:51
My 'C' originally had a 3-way switch for low charge/high charge/lights. I was told I cannot get this switch anymore so I am trying to figure out how to hook up the generator and lights without it. I was told to connect the 'field' post on the generator to a ground and this would give me a high charge. Instead, I am getting a negative charge. Does anyone have a diagram that shows the conversion of a 3-way charge switch to separate lights and generator connections, or has anyone done this? Your help is greatly appreciated.
Emmitt Persinger
06-27-2003 18:53:35
 Re: Allis C wiring in reply to Duane, 07-17-2000 17:28:51
Go to Dittmars on e. sixth avenue in Lancaster, Ohio and you can buy the switch for about $ 16.00
Sandy Lake Implement
07-18-2000 19:49:01
Grounding the field should produce high
charge. If it shows a discharge (and your
meter is wired correctly & battery is hooked
up pos ground) then you have a generator
problem.Call for more info-724-376-2489
8-5 EST. Ask for Bill or 8-12 Sat.
