What year is my wd
t.d
07-16-2000 08:42:39
I have a ac wd. the serial no. on the axle is
wd 100377. the no.on engine is u3019-3.
any info would be helpfull.
Brian G
07-16-2000 09:37:29
 Re: what year is my wd in reply to t.d, 07-16-2000 08:42:39
t.d., The number you gave from the engine is the block "casting" number. If you look on the side of the block just under the hose from the air cleaner to the carb, you'll find a smooth "boss" on which is stamped the engine serial number. It should start with "WD" and end with either PA (gasoline), GA (gasoline, I think) or KA (distillate, tractor fuel or LOW octane gasoline). I would guess your engine serial number will be in the low 300,000 range. Brian G.
Tom in Minnesota
07-16-2000 08:54:24
Late 1951 from the serial number, the 52's started at 105,000 (plus a few) -- there is a link to serial #s on this website.
