P/S Pump Leaks
Mike
07-12-2000 05:59:33
I have noticed P/S fluid coming out from the base of the distributor where it attaches to what I believe is the Power Steering pump on my D-17. If I am correct so far I am assumning there is a leaking seal which needs to be replaced on the P/S shaft that turns the distributor. How complicated is that to replace? In other words can I do it, or do I take it to a mechanic. I would assume further that there are timing marks somewhere that would need to match up and I would need to retime the engine.
Appreciate any help. Thanks
Mike
Phil Auten (TX)
07-13-2000 04:45:28
 Re: P/S Pump Leaks in reply to Mike, 07-12-2000 05:59:33
Mike,
Spend about $20 and get an I&T manual that covers the D-17. That will give you an idea of how hard it is to replace the seal.
As to retiming the engine, as long as you don't turn the engine after removing the distributor, you should be able to reinstall the pump and distributor without any problem and the timing should be correct.
Phil
