Model B Rear Wheel Clips
Rick in NC
07-07-2000 05:26:48
The eccentric bolts on the left rear wheel of my Model B will not tighten the clips as tightly against the rim as they should. The result is that the clips slip on the rim slightly and are wearing shiny spots so the problem will only get worse over time.
My question: Short of getting a new rim, what is the best fix to the condition? I have thought about two solutions: 1. Have the clips welded up and ground back down to fit the rims - this may be expensive. 2. I have some sheet aluminum that I have considered cutting into strips and using as a spacer between the wheel clips and the rim. What are your thoughts on the problem?
Thanks for your help!
big fred
07-09-2000 16:06:02
 Re: Model B Rear Wheel Clips in reply to Rick in NC, 07-07-2000 05:26:48
Rick, aluminum in contact with steel will be a corrosion problem. Better to use a steel shim, maybe something you could cut out of a tin can?
Dick L
07-07-2000 07:05:07
Do you have two per wheel or four? I bought a B from a guy that couldn't get them tight and he had put the solid ones opposit each other and the adjustable lugs opposit each other. The one C I bought had four adjustable lugs per wheel. I also have a C out back that has shimms under the lugs.
Rick in NC
07-07-2000 08:09:18
 Re: Re: Model B Rear Wheel Clips in reply to Dick L, 07-07-2000 07:05:07
Dick,
I have 2 adjustable ones per wheel. I have the two fixed ones beside each other with one of these engaging the driving lugs on the rim. The two eccentrics are opposite these.
What I may do is find another eccentric clip and bolt and put a third one on the wheel to see if that will help.
Thanks for the idea.
Sandy Lake Implement
07-09-2000 16:49:11
 Re: Re: Re: Model B Rear Wheel Clips in reply to Rick in NC, 07-07-2000 08:09:18
Original issue was 2 eccentrics per wheel. More can be added as needed. We stock them
& may have some used ones.
