Magneto timing
Brett
07-07-2000 04:32:12
Hi all, I've got a dilema. I'm trying to time my magneto on my AC model C. I need to have the motor on #1 cyl. TDC. What does the timing mark on the flywheel look like ? I think that I see a "F" thru the inspection hole on the bottom of the tractor. Thanks, Brett
Phil Auten (TX)
07-07-2000 05:19:34
 Re: Magneto timing in reply to Brett , 07-07-2000 04:32:12
Brett, The F is the correct timing mark. Try cleaning the area a bit and mark it with chalk or a crayon so it will be easier to see.
Phil
Dick L
07-07-2000 07:58:11
 Re: Re: Magneto timing in reply to Phil Auten (TX), 07-07-2000 05:19:34
It's the inspection hole on the left side not the bottom , on the C.
Sandy Lake Implement
07-09-2000 16:53:45
 Re: Re: Re: Magneto timing in reply to Dick L, 07-07-2000 07:58:11
The F or FIRE mark is to be used for timing
with a strobe light while running at over
1/2 throttle. Static timing shoud be done
to the CENTER mark which will be app 3/4"
away from the FIRE mark. It should be in the
center of the side hole when the mag trips.
Brett
07-10-2000 04:20:10
 Re: Re: Re: Re: Magneto timing in reply to Sandy Lake Implement, 07-09-2000 16:53:45
Thanks everybody. Sorry I didn't get back right away. Brett
