D19 hyd pump
TY
07-05-2000 17:22:07
I would like to install a low pressure high volume hyd pump on my D19. Where can you mount a front mounted pump? what kind can you use? I have thought about using a D17 IV pump. If I get all The hardware for the D17 will it fit in the D19? From looking in the repair manual I would have to use a D17 splined clutch also.
Sandy Lake Implement
07-09-2000 16:59:45
 Re: D19 hyd pump in reply to TY, 07-05-2000 17:22:07
OEM set up for a loader pump was front mounted
driven from the crankshaft by a splined shaft & front pulley coupler. We had a used asy this spring but none now. This pump put out app 8 gpm.
Not terribly high volume but better than the piston pump. It used the loader frame as an oil
reservoir.
