Spark Plugs for WD
Tom in Minnesot
07-05-2000 08:11:56
1951 WD with new head and old rings; burns a bit of oil & mild spark plug fouling -- all cylinders equal, no bad ones. Will do the rings next year but in the meantime, what would be a slghtly hotter alternative to Champion J-8-C's ??
Phil Auten (TX)
07-05-2000 11:28:16
 Re: Spark Plugs for WD in reply to Tom in Minnesota, 07-05-2000 08:11:56
Tom,
I've been using Champions in all my old iron, but the last plugs I got were Autolite and I've been pleased with them. Your counterman should be able to recommend a replacement that is one or two heat ranges hotter to help the fouling problem. If he can't do that, it's time to find a new source for your parts!
Phil
Brian
07-08-2000 14:11:56
 Re: Re: Spark Plugs for WD in reply to Phil Auten (TX), 07-05-2000 11:28:16
The AC Delco 45 is the equivialent to the J-8 Champion. The AC plug seems to be a hotter plug than the J-8. Personally, my experience is Champions are a waste of good money, and were a smudge on my reputation. With an oil burner, put in a new thermostat so it gets up to temp and try AC 47's in it. Hope this helps, Brian.
River Dale Farms
07-08-2000 06:12:10
Good answer on the plugs, also think about an electronic ignition. Thanks, Dale. Call us for info 920 295 3278
Sandy Lake Implement
07-09-2000 17:03:33
 Re: Re: Re: Spark Plugs for WD in reply to River Dale Farms, 07-08-2000 06:12:10
Use AC Delco or Autilite (which is who makes
the OEM plug) Allis # 79001652. If you like changing plugs then Champion is the best choice-
you will get to do it every 2 hours!!!
Brian
07-10-2000 13:57:39
 Re: Re: Re: Re: Spark Plugs for WD in reply to Sandy Lake Implement, 07-09-2000 17:03:33
What do the shop folks at Sandy Lake reccomend for plugs? Like I was saying, through trial and error, the AC Delco 45 plug seemed to last the longest before fouling under light use with Motorcraft A7C being a close second. I haven't tried Autolite plugs yet. Brian
