Allis-Chalmers D-19 loader
Mike Wilson
07-04-2000 17:34:14
I am looking for a front loader for a D-19 allis. I am located in central Kansas. Thanks for any help that you can give me.
TY
07-05-2000 17:14:10
 Re: Allis-Chalmers D-19 loader in reply to Mike Wilson, 07-04-2000 17:34:14
I don't know where you can find one. I'm looking for one too. I think a AC 500 would work best. The only problem with a D19 and a loader is the hyd. system. most modern loaders require low pressure high volume hyd. D19 has high pressure low volume. When I find a loader I will probaly install another hyd pump.
mike d
07-08-2000 18:40:12
 Re: Re: Allis-Chalmers D-19 loader in reply to TY, 07-05-2000 17:14:10
The D19 hydraulic system pump delivers 2000 psi as stated in the service manual. This is not a high pressure pump. I am not sure of the actual flow rate. I thought I saw listed in a loader web site a flow rate of about 5 gallons/minute which is lower than most modern tractors. It may operate the loader slowly. I am in the process of mounting a Koyker K5 loader on my D19. I will let you know how it turns out.
