Model B
Kevin
06-28-2000 19:24:25
I just bought a B on sunday. I have not yet bought the manuels,I need to mow with it this weekend and I need to service it. What gear lube do you put in the trans/rearend?
Do the hydrolics use the same fluid?
and do the bull gears use the same?
It is a 1949 model.
Thank you
Kevin
Ted Seifert
07-06-2000 21:07:09
 Re: model B in reply to Kevin, 06-28-2000 19:24:25
With hydrolic use 20 wt hydrolic oil so it won't foam. The manual that said 80wt was for non hydrolic B's Remember hydrolic was an option. I have 5 B's.
Ted Seifert
Jim
06-29-2000 19:44:06
My manual says all three take the same
lube S.A.E. 20W. Change twice per year.
Final drives 1.5 pints.
Trans-rear 6 qts., 7 qts. with PTO.
Hydraulics draw from transmission.
