Rust in tanks
dan
06-28-2000 18:11:15
I forgot the chemical you guys said you use to
break up rust in fuel tanks.Was it lye?any help
is always appreciated. thanks,Dan p.s.GO TRIBE!
Paul from Michigan
06-29-2000 19:58:50
 Re: rust in tanks in reply to dan, 06-28-2000 18:11:15
Don't know about chemical to remove rust, but I have had good luck withold bolts, nuts, etc. and a good shaking. For a permanent repair have the tank plastic coated inside to prevent future rust. I have had four or five done this way and had no more problems, even though they sat unused for months at a time. Advantage of nuts and bolts is they wont cover the outlet if you miss getting one out and they are easy to get with a magnet, which don't work real good on pea gravel as I have also seen recommended. Good luck, Paul
