WD Carburator Icing
Dave
11-23-1998 11:59:16
When air temperature gets cold(below 40)
the carb will ice up at the bottom of the manifold and run really rough. How can I stop
this from happening? Thanks for any reply.
john in MN
11-26-1998 03:59:23
 Re: WD Carburator Icing in reply to Dave, 11-23-1998 11:59:16
Go to the auto-parts store and buy some metal-foil flex-tube (like is used on your auto air cleaner). Take your air intake tube off your aircleaner (air intake side) ducktape the foil-tube on and run other end across the exhaust manifold, use wire to secure it.
This should warm your intake air enought so it does't ice up.
Worked for me.
john in MN
Dusty
11-23-1998 19:32:00
: When air temperature gets cold(below 40)
: the carb will ice up at the bottom of the : manifold and run really rough. How can I stop
: this from happening? Thanks for any reply.
Dave,
Try some dry gas.
Good Luck,
Dusty
Doug Ringer
11-30-1998 07:47:21
 Re: Re: WD Carburator Icing in reply to Dusty, 11-23-1998 19:32:00
: : When air temperature gets cold(below 40)
: : the carb will ice up at the bottom of the : : manifold and run really rough. How can I stop
: : this from happening? Thanks for any reply.
: Dave,
: Try some dry gas.
: Good Luck,
: Dusty
Dave,
Our 1941 Farmall M does the same thing. Dad solved the problem
by fastening styrofoam panels (the kind used for house insulation) to the hood and lets them hang down to cover the sides of the engine.
The engine warms up in a few minutes and the icing is not a problem
any more.
Doug
