WD hydraulics
Farmboy
06-27-2000 20:32:03
Finally got my WDrunning but hydraulics don't work right. It won't raise till the lever is about 80% up then it raises all the way. Then the it lowers at the same position but all the way down. No stopping anywhere in between. I have turned both the knobs on the pump with no change. I did move the lever linked to the draft control and it raised the arms but it also raised them all the way after letting go it lowered all the way back. Also, if I clean the valve, do I replace anything or just clean it? Any help would be appreciated.
Farmboy
Dave Kolby
07-03-2000 16:07:37
 Re: WD hydraulics in reply to Farmboy, 06-27-2000 20:32:03
There are three ways to set up the hydraulics on the WD. I can e-mail or fax you a copy of the set-ups if you want.
Dave
Rick Steele
09-09-2004 16:55:35
 Re: Re: WD hydraulics in reply to Dave Kolby, 07-03-2000 16:07:37
if its no problem i would like t have a copy of the set-ups . i have a wd and am haveing trouble . would appreciate it if possible.
