Wd45 hydraulics
Dave Grubb
06-27-2000 07:40:00
To cure the creeping lift problems with the lift arms: ensure all of the items mentioned in the I&T shop manual #AC-11 are met. In order of repair: 1-hold valve does not leak, 2-linkage is adjusted correctly, 3-pressures are correct, 4-if all parameters are met the last item to check is the operating clearance between the camshaft(item 35)/the plunger(item2)/and the ball(item1)in figure AC165 page 91 of the AC-11 manual. This clearance must be .012" to .015" with the camshaft at its lowest position relative to the plunger. If there is no clearance the lift arms will creep up and down. If there is too much clearance the lift arms cannot be lowered after raising. The operating clearance gradually decreases due to the ball being reseated. Be careful to maintain the same profile when removing material from the camshaft end of the plunger when adjusting the operating clearance- it is part of the detent feel in the hand control. This clearance is determined with the use of a depth and c micrometer. I hope this helps everyone, it drove me crazy until I figured this out.
Dave Grubb
06-27-2000 09:20:53
 Re: Wd45 hydraulics in reply to Dave Grubb, 06-27-2000 07:40:00
One correction. The clearance between the camshaft/plunger/ball is to be checked with the camshaft at the neutral position.
Sarge
06-29-2000 17:35:10
 Re: Re: Wd45 hydraulics in reply to Dave Grubb, 06-27-2000 09:20:53
Thanks For the info, Dave!
