ED 40 live pto
larry wolfe
06-25-2000 09:57:49
MY ED 40 has a lever to stop tractor motion and let the pto run. Now it seems to be slipping when I release the lever. Is there any way to tighten or adjust this clutch. Thanks in advance.
Sandy Lake Implement
06-26-2000 19:23:54
 Re: ED 40 live pto in reply to larry wolfe, 06-25-2000 09:57:49
This clutch is like that in the CA.
The likely problem is corrosion preventing
the balls & ramps from torquing apart. Would
need removed & cleaned up.Call 724-376-2489
for more info. 8-5 EST
larry wolfe
06-27-2000 09:15:56
 Re: Re: ED 40 live pto in reply to Sandy Lake Implement, 06-26-2000 19:23:54
I don't have experince with a CA either. I will try some local guys that have small AC's. I have to use it now because other machines have broken. It should be ok on leval ground.
