WC gas tank
Bobby Ellis
02-15-1998 22:02:20
I am getting gasoline leakage through my gas tank. It doesn't seem to be dripping, but is staying wet on the outside. Has anyone had good luck with using rust remover and coatings for gas tanks? If so where did you get it? I plan to get a JC whitney catalog and check out what they have. Any help would be appreciated.
Thanks,
Bobby Ellis
Robert Boswell
02-19-1998 17:23:00
 Re: WC gas tank in reply to Bobby Ellis, 02-15-1998 22:02:20
: I am getting gasoline leakage through my gas tank. It doesn't seem to be dripping, but is staying wet on the outside. Has anyone had good luck with using rust remover and coatings for gas tanks? If so where did you get it? I plan to get a JC whitney catalog and check out what they have. Any help would be appreciated.
: Thanks,
: Bobby Ellis
I've used a tank sealer that I purchased from a place in California called The Shop.I've been pleased with the results.Make sure that the tank is clean and use tank etch so that the sealer will bond to the tank.
