WD45 lubricants
Garry
06-23-2000 04:54:04
Can I use trans-hydraulic fluid for both the hydraulic pump and the transmission. The manual says use 20 wt for the hydraulic pump and 80 weight for the transmission/differential.
Thanks,
Wayne WI
06-24-2000 14:25:58
 Re: WD45 lubricants in reply to Garry, 06-23-2000 04:54:04
Garry, If you don't have a owners manual I would suggest ordering one. It sure helps as far as fill points, capacities, and oil weights. They are available on line. The hyd fluid is 20w non detergent oil and the diff. does get 80w oil to the tune of about 18 qts. I hope this helps.
