D-17 Series IV
Fred McIntire
06-21-2000 20:34:31
I'm considering purchasing an A-C D-17. It is in decent shape. My biggest concern is the hydraulics on the lift. The arms will lift up fine; however, the arms will not go back down without being forced down. Does this tractor have a power up/gravity down valve or is there a problem here? I should mention this is without any implements attached. Is this a good general purpose tractor. I have 46 acres and I plan on doing some hay this coming spring. Also, who makes the best 3 point adapter for these older tractors. I don't want any junk. Any help on this concern or any input in general would be greatly appreciated.
TY
07-05-2000 16:55:11
 Re: D-17 Series IV in reply to Fred McIntire, 06-21-2000 20:34:31
A Series IV will have the hyd. pump mounted on the side of the tractor where to belt pulley would go on the erlier models. I have never seen a series IV without 3-point. I think you could get snap-coupler as an option though.
Terry
06-24-2000 14:40:14
I thought all the D17 Series IVs came with a 3 pt hitch as standard equipment. I found out the hard way that the decals mean nothing. As I was told check the serial number, series IV begins with 75001. Either way D17 is good tractor. Terry
mikedom
06-22-2000 11:05:41
Fred-
Having to push the arms down is not uncommon, I have to do it with my D17 Series III. They will come down, but very slowly. This is an excellent haying tractor, around 50 pto horsepower. I have checked everywhere, and I think Saginaw makes the best 3 point adaptor for these tractors. I will be buying one soon myself. My 2 cents.
