190XT hp
dave g
11-21-1998 06:08:00
What is the hp rating of the ac 190xt? Any recurring problems with this tractor? Is it weak in any of the drive components? Also, doe anyone know if the results of the Nebraska Tractor Tests are on the net? If so, where can I take a look at them? Thanks.
Ted Buisker
11-22-1998 10:23:47
 Re: 190XT hp in reply to dave g, 11-21-1998 06:08:00
: What is the hp rating of the ac 190xt? Any recurring problems with this tractor? Is it weak in any of the drive components? : Also, doe anyone know if the results of the Nebraska Tractor Tests are on the net? If so, where can I take a look at them? Thanks.
They were rated about 93 HP, but most of them came from the factory at anywhere from 100 to 115 HP at the PTO. Early models had weak rear ends and transmissions, so look for a series III, they seemed to have the problem solved by then. But it is still a good idea to shift carefully, so as not to grind the gears to lengthen transmission life. They are a nice handling tractor with plenty of power for its size. Good luck and G'day. TED
