Splitting a C Allis Chalmers
Tom
11-21-1998 03:16:32
I need to replace the ring gear and clutch, and never having "split" a tricycle tractor apart before, I would like to know the best way to support/hang/prop-up the engine half of the tractor. The rear part shouldn't be too hard as it's stable, and the torque tube can be blocked up. I had thought that perhaps attaching a chain sling to a couple of head bolts, and suspending the engine half with a chain hoist would work. Any suggestions out there. By the way, this 1948 "C" is still very much a 'working' tractor. Thanks.
Nellie
11-22-1998 05:27:01
 Re: Splitting a C Allis Chalmers in reply to Tom, 11-21-1998 03:16:32
: I need to replace the ring gear and clutch, and never having "split" a tricycle tractor apart before, I would like to know the best way to support/hang/prop-up the engine half of the tractor. The rear part shouldn't be too hard as it's stable, and the torque tube can be blocked up. I had thought that perhaps attaching a chain sling to a couple of head bolts, and suspending the engine half with a chain hoist would work. Any suggestions out there. By the way, this 1948 "C" is still very much a 'working' tractor. Thanks.
I used a pipe tripod outdoors to remove the engine. Try and get the tripod over the center of the engine, attach something to your engine to lift from and use your hoist. Just about the way you had planned on doing it.
