WD-45
D17 - D19 Diesel Manifolds-interchangable???
JDGnut
06-18-2000 21:48:24
We have a WD45D with the 230 buda engine. We are wanting to know if the exhaust manifolds off the D17 or the D19 or another tractor will fit on this engines.. (What about the Intake manifold) I know that the exhaust outlet is in a different location, but that is not a problem.. any ideas.. Thanks for the help.. JDGnut
LB
06-19-2000 06:30:25
 Re: WD-45 - D17 - D19 Diesel Manifolds-interchangable??? in reply to JDGnut, 06-18-2000 21:48:24
I'm not sure about that. I would think D17-D19 would be interchangeable. D19 outlet is squared off and rotated to facilitate the turbo charger. I'm wondering myself what needs to be done to put a Buda 6 cyclinder engine into a D17 4cyl gas tractor.
JDGnut
06-20-2000 01:30:31
 Re: Re: WD-45 - D17 - D19 Diesel Manifolds-interchangable??? in reply to LB, 06-19-2000 06:30:25
As far as I can tell it shouldn't be to hard to put the diesel engine in the gas tractor.. You will need the adapter plate for the engine to the Trany.. On the WD45's the Radiator is different and I think the water pump is too.. Also on the 45's the left side frame is bent down to provide room for the pump.. Not real sure on the D17...
we are looking for better air flow with the different manifold... Good luck..
JDGnut
