PTO Shaft
Tom
06-18-2000 19:06:10
I hava an Allis B and I wanted to know if anybody knew if it is possable to change the pto shaft from a small one to a larger one, other than using a pto shaft adapter. Can you change out the gear or the housing. I can't even find a yoke for the small shaft, and I really need the bigger shaft. Thanks to anyone for there time and knowledge on this information.
Phil Auten (TX)
06-20-2000 05:28:42
 Re: PTO Shaft in reply to Tom, 06-18-2000 19:06:10
Tom,
My '40 B has the splined sleeve that Robert mentioned and it seems to work well with a pull behind mower.
Phil
Robert Mull
06-18-2000 20:00:16
The later model "B" had the 1-3/8 shaft. You might luck up and find one . Also you can get a increaser that is like a Splined bushing that won't add any length to the shaft.
