AC High Pressure system and cylinder
SuperCmore
06-09-2000 12:36:11
I'm an IH fan, but need to know the following. I have a 39 Farmall F-20 with belly pump off an H. Works fine. Will this pump work a cylinder originally used on a WD-45..I know Ac's had high pressure hydrolics, and old IH's low pressure. Will this pump work this cylinder? It's just a one-way pump. Thanks much, SuperCmore (also big WD-45 and D-17 and 190XT FAN!!)
skipwelte
06-09-2000 15:17:25
 Re: AC High Pressure system and cylinder in reply to SuperCmore, 06-09-2000 12:36:11
The pump will work the cylinder, it will go out fast but wont have much lifting power due to the low relief valve setting on your pump.
