AC plow identity
need help
JCB
06-08-2000 03:21:44
I am trying to identify what model AC plow I have. It is a 3-14", snap coupler, mounted that is very simular to a 62 or 63 mounted plow. Major differences are: The lift bar is u-bolted to the main frame rather than running through it and then held in place by set screws. The lift straps are both turnbuckles (one longer than the other). The stub beams are mounted at a 90 degree angle to the main plow frame, not the 60-70 degree angle of the 62 or 63. Any help would sure be appreiated. Thank you.
RMD
06-10-2000 19:22:42
 Re: AC plow identity - need help in reply to JCB, 06-08-2000 03:21:44
The 90 degree angle would imply a model 53 "square beam" plow, which is by far the most common plow for a WD.
