Hydrolics
Dick
06-07-2000 12:40:36
I have a wd45 not sure what year, it has a 3 point converson and worked good until I added front loader. now I can use either rear ar front not at same time I have to disconnect loader and plug it to get the 3 point to work ? do I have it hooked up wrong I hooked it to the remote hose that went to the back of the tractor
Aaron
06-07-2000 16:49:48
 Re: hydrolics in reply to Dick, 06-07-2000 12:40:36
Thats the way the pump is set up. You get one or the other. Makes using both near impossible.
Aaron
Scootyd
06-20-2000 07:12:56
 Re: Re: hydrolics in reply to Aaron, 06-07-2000 16:49:48
We had the same problem with my fathers WD. We added an on/off 1/4 turn valve on the jack before the hydraulic line that feeds the loader. With the valve off the bucket stays still and the blade works. Open the valve once you've raised the blade and the loader works. Not great but functional.
