Allis wd hydrolics
ralph
06-04-2000 19:41:20
i need help with the pump on my tractor,it works somtimes and somtims the lift dosent work.when
it isnt working you can hold the [foot] clutch in
for 30 seconds or so and then it will raise a
little.ther is a couple of diffrent adj.on the
pump but none seem to help
thankyou anyone
Will
06-05-2000 08:04:43
 Re: allis wd hydrolics in reply to ralph, 06-04-2000 19:41:20
Yes, use the hand clutch while you are in gear or keep it in neutral with the foot clutch out. The pump will not operate with the foot clutch depressed. Also check your fluid level.
brian
06-05-2000 03:53:59
if your stepping on the foot clutch you've disengaged the power to the pump and the lift will not operate if you need to raise the lifts after stopping use the tranny clutch that way the pump is always running.
