WD Burning Oil?
Tom in Minnesot
05-31-2000 08:23:03
Is it normal for a WD to burn a bit of oil, and if so, how much is reasonable?? (Valves ground recently, but rings not done.) Engine runs great and seems to have plenty of power.
Dave kolby
06-02-2000 12:20:17
 Re: WD Burning Oil? in reply to Tom in Minnesota, 05-31-2000 08:23:03
I would say it is certainly not "normal" for them to burn oil. Have owned two new ones and never burned oil. However any engine will wear and eventually burn oil. Some things to look for are broken or stuck piston rings and worn valve guides.
A compression check should help determine if all cyl's are bad or which one might be. Looking at the spark plugs may help also. As long as it is not excessive consumption and runs and works fine just consider a future overhaul.
Dave
